wider?
Discussion in 'Wheels and Tires' started by mavmanerick, Jul 12, 2007.
  1. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    If price is the main determining factor, then option "2" is the best, otherwise, I'd go with option "1"...
  2. mavmanerick
    royal city, washington
    today i found a falcon with stock 4x4.5 bolt pattern 14 in. rims with 215's on the back and 205's on the front.. as a matter of fact they were the same wheels that are on my car.. hmmm??
  3. T.L.
    T.L. Banned
    Southern Colorado
    If you want it to look like crap (sidewalls tucked inward) and be potentially unsafe, then go ahead & put those tires on those wheels. I had 195/70-14's on my stock 4.5-inch wheels back in '85, and they were too wide for the wheels, and they looked kind'a stupid. Soon after that, I got some 14x6" Modular "black nugget" wheels. Drove it like that all through high school, and upgraded to 205/70-14s. Then, in '88, I got some 14x7" "Magnum-500s" and got some 235-60-14s. I ran those for many years until I finally (just a couple months ago) got some 15x7" Magnums with 215/60-15s up front and 235/60-15s out back.
    Why am I telling you all this? Because my point is that you should get what you can afford for now, as they are most likely not the last wheels & tires your car's ever gonna have...
  4. mavmanerick
    ok i really dont wanna sound like an a-hole by shooting down your suggestions but maybe i have bigger rims than 4.5 cause my 195 really dont look like the side walls are sticking out..
  5. T.L.
    T.L. Banned
    Southern Colorado
    Well I thought you said you had the 4.5s. You need to find out for sure, before buying tires.
    And the sidewalls would not "stick out", they would tuck inward...
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I would establish what width wheel you have on your car currently. Then a decision becomes more educated, which usually means a better decision.
    Dan
  7. mavmanerick
    i just assumed cause you guys said the older mavs were 4.5.. is there a way to measure them with the tire on?
  8. Dan Starnes
    West Central IL
    Things get changed over the years. Your car may not have original wheels. I dont know of any way to measure wheel width but to take the tire off.
    Dan
  9. T.L.
    T.L. Banned
    Southern Colorado
    I don't know without checking, but I seriously doubt that the 4-lug wheels were 14x6"...
  10. mavmanerick
    ok one last question (i think)... i think for now im just gonna get the same size as on now until later when i swap it to 5-lug. but do you think it would look better 70 series rather than 75? or 75 on back and 70 on front?
  11. T.L.
    T.L. Banned
    Southern Colorado
    You can run 70s with no problem. They are 3/4 of an inch shorter than the 75s.
    I'd keep 'em the same size for all 4...
  12. mavmanerick
    ill decide tomorow.. i really appreciate you guys taking your time to answer my questions even though it might not sound like it... thanks
  13. Craig Selvey
    You can measure the wheel width with the tire on. Go to any tire store and they will have a set of calipers to do that with.
