Will I be ok with this cam?
Discussion in 'Technical' started by ford84stepside, Sep 2, 2006.
  1. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    the engine is a 84 vintige out of a T-bird. if its all original ,they were equiped with bolt down rockers. ford racing sells bolt down rockers and springs and dont need to machine for studs or guide plates and harden push rods. or take the oem rockers to a machine shop and have them modified the slots on all 16,but do change the springs and get new lifters !! you dont know how much abuse and mileage the motor has. oh forgot !! what ever springs you get ask about the installed hieght and shim(if needed) for proper seat pressure. good luck!!!!
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    The carb IS a single line Vac sec, 650 cfm, not a double pumper.
  3. ford84stepside
    Berry Alabama
    I guess I forgot to add I bought a used cam with matching lifters, supposed to only have about 3000 miles on the set...
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't mean to be a buzzkill, but they say that you MUST get all of those used lifters back onto the same lobe that they were broken in on.
    Otherwise you are supposed to use new lifters and re-break them in.
    I don't know this is a fact, I have always just figured it was cheaper to get lifters than ruin a cam and waste the labor.
    Dave
  5. ford84stepside
    Berry Alabama
    The guy says he he put the lifters in a numbered block when he took them out. If he is truthful about it, and sends them to me that way, I don't think I will have any problems with them. On the other hand, if they arrive loose in a bag, I will go ahead and get a new set. I have heard the same thing, but years ago, before I knew better, I put a engine back together without keeping the lifters straight, and never had any problems with it. Put over 100,000 miles on it, maybe I got lucky, don't know. A little [:bs:well, alot] older, hopefully a lot wiser!
