will the gas tank fit
Discussion in 'Technical' started by g_field07edd, Aug 8, 2009.
  1. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    i need to see some pix of a stock tank in a 71 or similar ,i have a modified tank, with no sending unit ,heck i dont even know where it goes ,mine has a 1/2 fuel line coming out the drivers side lower of tank but no wires terminal conector for a float ,any where ,i do have the wires for the sender front the front there though
  2. rthomas771
    You can still buy the vapor valve and garment to fit the 77 tank from Ford, Auto Krafters or Rock Auto. I bought longer bolts at Lowe's...but I had to cut the length. The stock bolts are about 1" too short.
  3. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    i put a fuel cell in my 73 and took my 73 tank and put it in my drop in car. i shaved about 1/8 off of each side and it slid right in. a peice of sheet metal for the gap on the front a peice of fuel line and was good to go
  4. ladyeclectic79
    ladyeclectic79 Veni, vidi, vici
    Hanford, CA
    A '73 and a '70 Maverick
    The gas tank from my new 73 Mav was taken out by the PO and replaced with an 8-gallon fuel cell. This won't work for me and I want another tank back on it but haven't found much luck so far. I've also got a 70 Mav I might be able to cannibalize but from what I hear the 70's tank won't fit the 73?
  5. Mavaholic
    The 70 tank just might fit under the floor. Dont know of anybody that has tried it since they are the hardest to find.
  6. 71gold
    Dennis posted these P#s...
    Grommet-F6TZ9B076AA
    Vent Valve-E7DZ9B593A
    :HandshakeDennis
  7. 71gold
    the vent and grommet i have in my new '77 tank came from a late model plastic tank. it was one that was removed from a car that was going to the crusher...sorry don't know what car...
