Will this be a direct plug n play?
Discussion in 'General Maverick/Comet' started by Lzoesch, Feb 27, 2011.
  1. simple man
    simple man Member
    Bunnell,Florida
    You may have to use relays to run those! Try them first and if they trip your headlamp switch circuit breaker you'll know relays are necessary. I believe these draw a lot more current than regular headlamp bulbs.:)
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I have similar headlight, but I used the Autoloc brand and are probably much better quality, but double the cost. I was going to say "Before you by them make sure they are glass lense and not plastic" but i see you already bought them. I also had to open up the back of the headlight bucket as mentioned earlier to fit the conversion bulb into the bucket all the way. I haven't ran relays yet but I probably will because I don't think my lights are as bright as they should be.
  3. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I put some like them in my 71 F100 plus I included relays. They made a great difference. The relays probably made most but I don't know since they were done at about the same time. Relays put more amps to the headlights and makes your headlight switch and dimmer switch last almost forever.
    Clint
  4. maverick75
    There's already a "How To" grassroots style conversion thread :)
