Will this compressor work?
Discussion in 'Tool & Shop Talk' started by will8069, May 29, 2010.
  1. PaulS
    Well the ad that you linked to says its a dual cylinder, 3.2 running hp
    with a 60 gallon tank. What is the CFM rated at what pressure?
    The ad didn't say. Mine is 17.? at 90 psi. (almost too small for some of my work)
  2. predfan2001
    "11.5/10.2 SCFM @ 40/90 PSI"
    Like I said....I want more. But it does everything I need it to do. My air grinder makes it cut on every 5-10 minutes if I'm using it steady....but that's a rarity. I used to do all of my painting with a 10 gallon 2.5hp. But now I'm wanting to run air tools....my old compressor wouldn't run tools worth a darn.
