Wilwood M/C install thread
Discussion in 'Technical' started by scooper77515, Dec 21, 2009.
  1. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Yes Scott that would be the combination valve (proportioning valve) and i'm not sure about the one you have but the Mopar style Willwood masters are internally proportioned so you eliminate the valve all together.The Mopar style is what you see in most drag cars,looks a little different than yours.
  2. scooper77515
    Well, that explains why my car stops on a dime, and doesn't try to fishtail or come around on me. That doohicky IS a proportioning valve.
    As for the pedal, I can pull it another 6-8 inches toward me from rest, so I DO need to make some sort of stop. I just need some suggestions on how to do it (hint, hint).
    I figure I can put a stop within a half inch or so of rest and be safe. That plunger rod goes into the m/c at least 2", maybe more.
  3. 71gold
    my ...disc...disc...system doesn't have a...proportioning valve or diverter block...in the M/C or otherwise...the lines come straight from the M/C to the calipers.
    i am of the thinking that being my rear tires and rims are larger than the front, they act as a ..."proportioning valve"...Strange M/C...1" bore.
    ...:Handshake...
  4. rthomas771
    The pedal support already has two holes on the left side of the channel. Bolt a peice of angle iron there and let the end of the angle iron come about 3/8" from the brake pedal.
  5. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    stop
    Drill the pedal bracket from side to side and install a long hitch pin..??
  6. bmcdaniel
    There's a reason the factory puts all of those twists and spirals into their brake lines. To survive vibrations, temperature changes and accidents.
    For a pedal stop on mine I just have a piece of angle hose-clamped to the steering column.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Scott,
    How's the pedal effort? My car was originally non-power 9" drum/drum and I converted to disc/drum using a Granada M/C and prop valve. The discs are 11" and the drums are the SVO 11" drum kit. I'm not sure on the M/C bore, but the pedal is stock (6:1?). My pedal is high and hard, but it takes a lot of effort to get stopped. I'm not sure I could "lock 'er up" if I had to...
    Russ
  8. rthomas771
    Sounds like you have a 1-1/16" bore and too of a long push-rod (Mustang?).
  9. scooper77515
    it will lock em up if I stomp it. I did it on the test drive. Pedal effort is not bad at all and it starts engaging pretty quickly. I think it starts to skid only because the car is so light. It doesn't appear to be a case of one wheel or pair of wheels locking up sooner than the others. And it only skidded for a brief second before landing at a complete stop staring straight on down the road, in the direction I was originally driving in. Didn't pull to one side or the other.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Dunno. :huh: It's a new Granada M/C and used Granada prop valve, I didn't measure the bore but I did have to swap my old pushrod over to it, as the one that came with the new M/C was too long. The pedal height is good, by "high and hard" I meant that the pedal doesn't go to the floor when braking. I'm thinking it has more to do with "upsizing" from 9" drums to 11" discs/drums. If it continues to bother me, I may end up with a hydroboost as no vacuum booster will fit...
    Russ
  11. rthomas771
    Drum/disc size has nothing to do with the fluid capacity of the wheel cylinders or calipers. You can use http://www.rockauto.com/ and look up what year Granada that you used to find cylinder bore. Bigger the bore the harder the pedal...smaller the bore closer to the floor.
  12. darren
    That was my first thought. What if that rod pops out of place if the pedal is lifted a bit????
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    No brakes!:D
