Wind shield removal
Discussion in 'Technical' started by blugene, Jul 27, 2006.
  1. blugene
    I'm keeping my fingers crossed for a clean removal. If it becomes a pain... well... [​IMG] :cool: :drink:
  2. RegL404
    RegL404 Member
    I wouldn't cut the seal unless you have another one to replace it with. I have removed both the front and rear glass by taking a screwdriver and getting between the seal and headliner and prying the seal down and gently pushing against the glass at the top close to the corners. once the top starts out, just keep peeling the seal back and pushing on the glass. It helps to have an extra hand, but I have done it by myself.
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The wire trick is really for late model windshields that are held in with adhesive. Gasket type windshields are really meant to have the gasket cut and the glass basically just lifts right out ... then a new gasket is used for reinstallation ...
  4. blugene
    [​IMG] Ok, Thanks for all the info.
  5. Jamie Miles
    Alto, GA
    I've had a few
    Just get a new seal, don't try to reuse the old one.
  6. blugene
    I plan on ALL new seals with headliner too.
    I should do the vinyl top at the ame time, right?
  7. dmhines
    Cumming, GA
    If you do a vinyl top .. it goes on after the windshield but before the chrome ...
  8. blugene
    So again I ask you gents, what would be the order to go by? I'm thinking that once I have it all cleaned I should paint. Then what's first, headliner?
  9. scooper77515
    Be sure to paint the roof really good before you pu the vinyl top on it. I would personally go with POR-15 or similar to keep the water from ever getting under the paint...
  10. blugene
    You shure do like that stuff. :16suspect You a repp of the stuff or sumthin, earning a commission?:rofl2: j/k
    I do understand, when you find a product you found that really DOES work, you want to tell everybody.(y)
    I will make sure to have a good coating on the top cause I already have a rust hole I have to address :( .
  11. Jamie Miles
    Alto, GA
    I've had a few
    I don't know about POR 15, but I used Rust Bullet in the trunk of Terry's '77 and was very impressed with it.
  12. yerg
    yerg Member
    okolahoma
    Blugene great article..you asked all of my questions...im pulling the glass out today going to paint and final body tomorrow...already have headliner,carpet in house
  13. blugene
    I left out one question tho. If anyone wanted to come do it for me :rofl2:. I havn't done it yet :(
  14. yerg
    yerg Member
    okolahoma
    sure right...taking the glass out was super easy...putting the headlinner in it is going to blow...ya ya i know get someone to do it....the whole point of teaching the boy is doing it...
