Does anyone make a kit to repair a regulator? I have another regulator with the fitting in place but it has some play in it.
My driver side regulator had a little play in it which caused the window to rattle while rolled down. Bought a regulator off of Ebay but when it arrived it was missing the fitting that bolts to the door. The seller then sent me another regulator which turned out to be for the passenger side. To eliminate the hassle of returning it I removed the arm from the passenger side one and placed it on the driver side one. I filed the pin a little and then flattened it out after installing it. I have not installed it in the car yet but it seems to have turned out OK.
