Windshield cleaning
Discussion in 'Cosmetic' started by blugene, Oct 26, 2007.
  1. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I concur with my fine friends here on the price. Very reasonable. Be picky on the extra sealing of it.
    Dan
  2. 71gold
    be sure not to loose the ...little clips...at the bottom of the window opening when you remove the old glass. they are buried in the old sealant...:yup:
    ...GFF...
  3. rayzorsharp
    Much better to just but a set of new ones. They tend to get distorted or broken when you remove them. You might save half of them...then you find yourself scrounging for the rest. Just make sure you get the right ones. Some of them are a little longer. If you try using the short ones, you'll destroy your moldings trying to get them to clip back on.
    Edit...sorry, this is actually for the back glass molding clips.
  4. don graham
    i know a couple that have a 64 fairlane that was scratched pretty bad. they said they used brasso and a lot of armwork. came out really good. i bought some but haven't tried it yet. that sounds like a great price to me also.:)
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I'm a smoker, and have found one of the best things to clean glass with is a newspaper. It's firmer than a paper towel, but not too firm as to scratch the glass. I use original windex brand, the knock off discount store doesn't work nearly as good. I have to clean my windows daily in the truck, so I get a lot of practice!
  6. blugene
    Thanks again for all the replys guys, they are good advise.
    Ray, you mentioned clips...I would like all new ones but seems the 73s are harder to locate for some reason.
  7. 71gold
    :sorry: I was refering to the ...little stands...at the bottom of the windshield.
    getting new...molding clips...is a good idea also.
    ...(y)...
  8. rayzorsharp
    Gene...did you check with AutoKrafters?
  9. blugene
    :16suspect Smarty panties...
    I will.
  10. Taxi Rob
    Taxi Rob Member
    San Diego, CA
    1972 Comet 200ci coupe
    been a few days...
    Did you get it done yet? I recently got my headliner done and bought new seals for the upholstery shop to install at the same time, but both windows have leaks. How did yours turn out? My glass is good, but buying the seals myself and paying for labor separately is almost as much as what you were quoted for the whole enchilada.
    Anybody else know a good method for prepping the opening to ensure a good seal?
  11. blugene
    It will be a few months...:(
    Do I need to have the rear window out to do the liner?
  12. Rando76
    Rando76 Member
    Claremore, OK
    Yes :(
  13. rayzorsharp
    Definitely yes...go ahead and get another window gasket. :2cents::2cents::2cents::2cents::2cents:
  14. blugene
    I am thinking about getting the package deal from AK...good? bad?...
    Thank you too Rando :Handshake
  15. 71gold
    Gene,
    did you get that ...glass...cleaned?:huh:
    ...:drive:...
