Windshield leaking!
Discussion in 'General Maverick/Comet' started by YellowStangDuan, Apr 13, 2014.
  1. 71gold
    those seem to be something someone made...I wouldn't think the gasket would seal using them.
  2. vvr210
    vvr210 Member
    Vista,CA
    Would you happen to have any?How many are used and are they also used on the rear windshield?
  3. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    It seems like Val is having the same problem as me. Mine does have 3 stands, I may try popping it out and trying again.
  4. blugene
  5. YellowStangDuan
    Arlington, Texas
    71 Grabber
    And I think mine is later, it's lighter. Gaskets are the same, I looked in my old AK book.
  6. 71gold
    I haven't seen any for the rear glass...
  7. Craig Selvey
    Not used on the rear glass.
    Email me.
  8. YellowStangDuan
    Arlington, Texas
    71 Grabber
    New thought... I removed it tonight, and I had cleaned the outside real good, but there was still a good amount of sticky butyl on the inside. I think that may have been preventing the gasket from rolling in all the way, keeping the windshield from seating. I cleaned it good, and thinking about lubing the pinch weld and gasket with Vaseline first. Going to try tomorrow.
  9. blugene
    That just might work.. I think using butyl might do the same and seal at the same time.
  10. YellowStangDuan
    Arlington, Texas
    71 Grabber
    I think the butyl stuck the gasket before it seated.
  11. blugene
    How? I watched a glass guy use some and it was ooy gooy till it set up a few hrs later.. He said it would fully cure in 24 to 48 hrs but suggested not pressure washing for at least 72 hrs.
  12. YellowStangDuan
    Arlington, Texas
    71 Grabber
    This stuff is 30 years old and has never cured, maybe it's not butyl. It is stringy, gooey stuff that is worse than chewing gum on a hot sidewalk.
  13. blugene
    Oh. Your talking about the old stuff. I'm suggesting to use new butyl in a tube that fits a caulk gun. I'm not sure what the old stuff is but your right. It's some nasty stuff.
  14. 71gold
    don't know if that would be a good idea or not. it may keep the sealant from ahearing to the gasket/pinch well...
  15. YellowStangDuan
    Arlington, Texas
    71 Grabber
    Cleaned everything up, lubed the rope, hosed everything down with glass cleaner. The bottom went in real easy, started doing the side, noticed I cracked it.... Gave up, put my old one back in. Seems to fit like the other, no better. I give up.
