wiring in my 73 mav
Discussion in 'Technical' started by 4door73mav, Mar 2, 2015.
  1. 4door73mav
    4door73mav Member
    1973 ford maverick
    Weird issues. My turn signals work one day then barely work the next,then not at all, then work fine again. Same thing with my aftermarket radio(which stopped coming on at all at this point). Also now my right rear brake light isn't working at all, even with new bulb and cleaned socket. Left brake light parking and reverse lights are all working fine. Any advice or suggestions? Thanks
    -kevin
  2. Craig Selvey
    Welcome to the Maverick world on the world wide web. Where are you located?
  3. 4door73mav
    4door73mav Member
    1973 ford maverick
    I'm in sacramento ca thanks for the warm welcome. I'm really happy I found this forum lots of good info here
  4. 71gold
    :Welcome:...:Handshake:
    check all ground connections...twice
    4door73mav likes this.
  5. Krazy Comet
    For the RR brake light check to see if there is power with brake applied on the Orange/Lt Blue wire where it exits the Crescent shaped signal switch connector... If it has power with brake applied, there is a problem in the harness between connector and lamp in back...
    If you mean the RR tail lamp isn't working at all, the socket ground is probably defective...
    Btw welcome...
  6. 4door73mav
    4door73mav Member
    1973 ford maverick
    Thanks for the tips! I'll check it tomorrow or the next day and give updates
    Here's a pic of my 73
  7. 71gold
    check this plug also for good connection.
  8. 4door73mav
    4door73mav Member
    1973 ford maverick
    Also I'm looking for a floor shifter to change from column shift to floor. Any one have a floor shift they're looking to sell?
  9. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Welcome to the site, you will get a better response on the shifter if you start a wanted thread in the classified section.
