Wiring mystery on my 73
Discussion in 'General Maverick/Comet' started by HarleyGA, Aug 9, 2020.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    See attached photo. Searching for a Maverick wiring expert. There are two light green/yellow stripe wires that merge into a single female bullet connector. Coming out of the same wire bundle is a black wire with a male Bullet connector. The problem is that there is nothing close by to plug these connectors into. Does anyone know what these wires do and where they connect. They are dangling under the right side of the dash. 93E8784B-76E6-4765-A714-F77C063E5DE8.jpeg
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Diagrams indicate lt green & yellow were for the door switches and connect to the fuse panel and headlight switch. Possibly for an additional lighting option? Is it hot, does it energize if you switch on the dome lamp or open one of the doors?
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    That could be for the optional courtesy light package?
  4. Krazy Comet
    Dismal Swamp
    Yep, should be originating from door light switches.
  5. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    The wires have 12 volts even with the ignition switch off doors closed and everything in the car turned off.
  6. Krazy Comet
    Dismal Swamp
    Green with yellow stripe is door switch circuit, hot continually means it's on feed(from fuse panel) vs switched lead. Circuit colors were standardized between carlines in the early/mid '60s, same for most if not all models.
  7. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Yes I know all of this. I have all of the factory wiring diagrams. What I am asking is where do the wires shown in my photo connect???? There are no wires anywhere in the vicinity for them to plug into. I took the passenger seat out so I could lie down with my head under the dash, looked everywhere for where they could possibly lead and came up empty. I’m hoping someone can look at their own car and see the same wires as in my photo and see what is plugged into them.
  8. Krazy Comet
    Dismal Swamp
    Probably for operating a under dash courtesy light. I'd bet same is in my Comet, never looked.
    I have such wiring in my Cobra & Fairlane, light for those also has switch to allow independent operation of door sw. It isn't installed in either, part of optional courtesy package neither has.
    Maverocket likes this.
  9. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
  10. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Solved my wiring problem. The mystery wires go to the glovebox light
  11. mojo
    Your 73 has a glove box? Didn't think they were on until 74's
  12. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    They added the glovebox in 73. Pretty shallow box but you can squeeze a pack of gum or two into it
    jasonwthompson likes this.
  13. 71gold
    my 73 had a glove box (busted) , swapped it for an earlier tray.
  14. f4294v
    f4294v Member
    Dallas
    73 comet
    I added a glove box light. Those wires were taped up in the loom. I just plugged switch into them and it works.
