Won’t start without brakes and stalling
Discussion in 'Technical' started by Deadpancaleber, Feb 15, 2021.
  1. Deadpancaleber
    Deadpancaleber Member
    Plant city fl
    73 mercury comet
    My 73 comet doesnt do anything when I turn the key until I hit the brakes then it starts right up.it also stalls when I put it in drive without hitting the gas. It also used to stall whenever I was driving normally but I replaced spark plugs and alt seemed to fix it but I will have to test it.
  2. 71gold
    :Welcome:...:Handshake:
    Deadpancaleber likes this.
  3. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Sounds like you have a wire from the key to the starter solenoid with insulation rubbed through and it shorts against the pedal until you depress it. No guarantees on that, but it's the first thing I'd think about.
    TeeEl likes this.
  4. 71gold
    "doesn't do anything when I turn the key until I hit the brake."
    sounds like any of the modern cars of today...:huh:
    Hotrock likes this.
  5. Krazy Comet
    Assuming the dash lights up but there is a no crank condition, I'd look at the neutral safety switch located at base of steering column.
  6. Deadpancaleber
    Plant city fl
    73 mercury comet
    Apparently someone had just knocked some wiring loose when they removed the radio
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    thats what I was thinking. My GF 2016 wont start till you step on the break.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    do you know which? Always good to know solutions for future reference.
  9. Deadpancaleber
    Plant city fl
    73 mercury comet
    no sorry but there’s only so many wires under the dash. I tried to recreate it but couldn’t .
