Worked on my dash today
Discussion in 'General Maverick/Comet' started by Jeff S, Apr 4, 2009.
  1. blugene
    I have alot of money up in the rafters of the garage, over in the corner(s), up on the tool box, here, there... I need to put it all together so it will add up to something.
    JPS, did you take the dash out to do the work? I have my glass out and that's the only way I see to take the dash out.
  2. Jeff S
    Jeff S Member
    NoVA
    none
    Didnt take the dash out, although I think the whole front section of the dash comes out separately from the back plastic section(that has the defroster vents).
    Underneath the dash pad is a seam, Im not sure whether the factory spot welded them together or not, but it seems to me it wouldnt be too hard to separate it.
  3. blugene
    Thanks.
    I have mine completly out and was just curious if you took yours out.
    I just dread putting it all back together. It seems things come apart easier than they go back together. I know for a fact they come apart faster :rofl2:
  4. blugene
    I added it to my favorites, juuuust in case...(y)
  5. Jeff S
    Jeff S Member
    NoVA
    none
    When I stripped my dash down I removed everything that didnt need to be there...about a week ago I stripped the engine bay of all AC components, and when I got under the dash I removed everything with the exception of the heater and the defrost vents for the windshield, all the huge vent lines and everything was taken out, so I have tons of room behind the dash now...lol
    instead of putting the lower panel back on under the main dash Im thinking about fabricating a custom panel just for fun...make it come out at the bottom slightly instead of following the dash line in so Ill have a place for gauges, switches, and such
  6. blugene
    Ahhh... good luck. Keep us informed. I have two lower trays so I can play too. Not sure yet what I might do there so yea, intrested to see what you come up with.
  7. Jeff S
    Jeff S Member
    NoVA
    none
    I added you to yahoo so we wouldnt be chatting back and forth in a topic, but youre offline.
    Im about to head out the door, started taking things out from the engine bay, Im taking them and stripping them down to bare metal, priming, and repainting...fun fun...trying to get the inside ready for a 302 so I dont have to do as much when I finally get it :thumbs2:
    Ill talk to you all later
  8. blugene
    Your gonna make me have to remember how to log on to that? :rolleyes:
  9. Jeff S
    Jeff S Member
    NoVA
    none
    Just sign in the Yahoo Messenger app :p
    your login name is kingg1965@sbcglobal.net ... I have no idea what your password is. :D
  10. Jeff S
    Jeff S Member
    NoVA
    none
    More updates on stuff.....got bored yesterday...these two things took a LOT longer then I thought, used a wire wheel and got them both down to bare metal...32 years of dirt and grime is NOT easy to get off, but the finished product was well worth it :D
    I do have a quick question...the inlet for the breather goes to the front, I know that...but where does the port on the underside of it go?
