Working on 73 Maverick AC Controls
Discussion in 'New Members Forum' started by maverick12, Jun 13, 2022.
  1. maverick12
    maverick12 Member
    Georgia
    1973 Maverick
    Trying to determine the problem with my blower controls, only blows defrost. Seems the vacuum switch assembly has broken. Any idea where I can order a new one?
    Russell likes this.
  2. Craig Selvey
    I see them on eBay from time to time. I suggest you check the vacuum canister under the hood first. If it leaks...it will do the same thing. A small bead of silicone around where the nipple attaches to the "can" will fix the leak. Check the hoses as well.
  3. maverick12
    maverick12 Member
    Georgia
    1973 Maverick
    Thank You. I will check that as well, but I now the vac switch assembly was shot so I ordered one from ThePartGuy.com If I still have problems I will check the vacuum canister
