Worn cam lobe symptoms
Discussion in 'Technical' started by 289, Dec 1, 2013.
  1. baddad457
    If you're running dual springs on pressed in stud heads, that's likely your problem, the rocker studs are being pulled out of the heads from the heavier spring pressure. Any thing bigger than Comp's 268H needs screw in studs, or pedestal rockers (bolt down)
  2. baddad457
    You're wrong. The cam gear can be at either 12 or 6 o'clock when timing the cam to the crank. The crank tirns at twice the speed of the cam. Thus it can be at either position and still be correct. Set it up at 6 o'clock, rotate the crank one revolution and the timing dot on the cam gear will then be at 12 o'clock.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No, it isn't. You can remove a rocker cover and look at the position of the rocker arms to see that both valves are closed.
  4. 71gold
    being the heads were just assembled, not likely bad...
    "i had the machine shop assemble the valves, springs, whatnot."
    these should fall under "whatnot"...
  5. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    That's how I do it, no dots required
  6. darren
    Before I waste any time getting in over my head I always stick with a basic vacuum gauge check as my first step if I suspect a bad valve or cam lobe.
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Not sure if you found the issue
    but what oil did you specifically use as on shelf oils have calcium detergents which is really bad for our engines more so when its a fresh engine rebuild or cam swap ..calcium strips any protective layer(zinc phosphorous and creates metal to metal contact)
    Z-paste for cam lube is the best
    Joe gibbs is another great choice
    Joe gibbs HR-2 is the best choice for oil with ZDDP and no Calcium detergents to strip any lube cushion..so no metel to metel contact
    joe gibbs BR30 is best for engine breakin
