Would this steering column work?
Discussion in 'Technical' started by Deerhog, Apr 27, 2017.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    I found a 73 cougar/Mustang steering column. Would that fit in my 73 comet?
  2. Krazy Comet
    While it's similar in construction, would surprise me if length is same... Mounting between dash and firewall is likely different as well as length from dash mount to steering wheel... The distance from steering coupler(rag joint) to firewall is also likely different...
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Diameter of the tube may be different as well, the Maverick column is pretty petite.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Let me add to the confusion. I had a 75 Maverick factory column shift automatic. When I converted it to floor shift I used the two top collar pieces from a 71 - 73 Mustang column, as they did not have the shift indicator or mounting hole for the column shift lever, on the factory Maverick column without issue. However, without careful measurements, I bet Tom is probably correct regarding the length differences.
