wrong kind of transmission fluid
Discussion in 'Technical' started by duster70, Apr 25, 2006.
  1. COOTER
    COOTER New Member
    SO CAL
    '60 Comet Wagon
    '60 Comet wagon trans
    I just purchased a '60 Comet wagon and am having the same problem as Duster70. I read through this thread and just wanted to verify that the same applies to the Merc-o-matic(?) trans? Also, is this trans known as a C-2 ? Thanks.
  2. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    Here is a report to support my reply #58.
    I just had an 02 4r70w 4x4 trans performace built to heavy towing application by Level 10. The clutchs and band materials as well as matching friction plates are now a different material than OEM.
    The trans original fluid was Mercon V. Now it is Dextron III to match the internal changes.
  3. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Delete comment. I didn't read all the way through.
    Buy a manual!
  4. Halebopp
    Halebopp Member
    Ankeny Iowa
    CAn someone tell me type f is the correct fluid for my C-4 right I've lost my way in this
  5. Jamie Miles
    Either Type F or Dexron/Mercon III will be fine.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you have a C4, Type-F is correct.
    If you have had different clutch materials installed or currently run any other fluid, then you are on your own from what is recommended.
    Will it hurt...
    I have heard people swear both ways at this point. Before now (this thread), I have only met folks that said their trannys were fine until they used Dex. Therefore it can obviously hurt to use Dex, even though others have had no issues.
