Xhaust Tip POll
Discussion in 'Cosmetic' started by maverick75, Oct 1, 2008.
were do the exhaust tips look better?
Poll closed Nov 20, 2008.
  1. Behind Rear Valence
    51.8%
  2. Behind Rear Tire
    21.4%
  3. other
    26.8%
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Mine look just like scoop's, except I have glasspacks instead of the blowmasters. Later I may have a set bent up to exit thru the springs like Dave's. The way my electric fuel pump is mounted, I don't have enough room to go all the way out the back....
  2. Bryant
    i just took off the turndowns, looked just like scoopers, and had tail pipe going back to the rear valance. i have a fuel cell in the trunk so there is no fuel tank to work around. the pipes stay tucked up behind the valance and you can only see about 1/2 an inch poking down. i did this to help keep the exhast smell out of the car and keep the sound down a little. it did help with the exhast smell and the sound level in the car but outside is only slightly quieter.
  3. maverick75
    *Mock up pics are now up on the first page*
    Right now i have turndowns but i like the look of exhaust tips
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Thrush sidepipes have square tips.
  5. draggon13
    draggon13 Member
    Hilliard, Florida
    1974 Maverick V8 5 Speed
    Dave,
    Isn't that BEHIND the rear tires??? Or do you have your gas tank under the rear seat instead of under the trunk???:rolleyes::rolleyes:
  6. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    angle it down in front of the rear tires! :burnout:
  7. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    Here's mine: stainless slant cut tips straight out.
    Angled behind the rear wheels (through the spring) is a good look too. A tough look. I think under the valence looks more refined. As long as its dual exhaust, its all good.
  8. scooper77515
    Damn...the more I see that orange car, the more I like it...:thumbs2:
  9. maverick75
    I think i'm going to put a 3bolt flange on the muffler outlet, then i can make different setups that i can just bolt on and off.
  10. 71_Maverick
    71_Maverick Member
    michigan
    i think mad max style on his interceptor(falcon) would be pretty cool to see
  11. signal20
    signal20 Paul VanSteen
    Spring Hill, FL
    this gets my vote:thumbs2:
