York to Saden 508 Air conditioning compressor conversion
Discussion in 'Technical' started by Allen Small, Apr 23, 2015.
  1. 71gold
    no PM
  2. 71gold
    thanks...it set too high for my liking.
    here is a better before and after... before it set half way up the dist.
    mojo likes this.
  3. texasbb14
    texasbb14 Member
    south carolina
    I sent another, if you don't receive it can you please email me at texasbb@hotmail.com
  4. 71gold
    got it...
  5. mojo
    I see what the difference w/ the b4/after. Don't know how that might work w/ my pwr steering pump, but wud seemingly work w/0 issue installing a monte carlo bar; what Allen wants. The bracket might be gud for a tech write-up! Also, might be something to consider an addition to your AOD trans cross member?:huh:
  6. Earl Branham
    Lugoff, SC
    Everett; the Monte Carlo bar on my car is the topoRanger bar he offers. it fits perfectly, no mods required. the bracket is an aftermarket one that came with the a/c system. Frank and I modded the beacket to set 5" lower to accomodate the M/C bar. My car doesn't have power steering so don't know how that would work. Doesn't look like enough room to me. but, looks like an easy bracket to make with the right tools and knowhow. Sorry I haven't been on here much. Lost my Dad last week, so been very busy with that. Hope things are fine on your end.
  7. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Allen
    I used the some a/c set up on my f100. I used both the tensioner and lower idler ( under a/c pump) to stop belt chatter.
    As for mounting bracket I made my own 3/8" square plate 4 taped holes to mount plate to factory a/c bracket and 4 tabs to mount a/c pump to bracket . It's necessary to pay attention to belt alignment and make sure the belt is running straight and true.
  8. 71gold
    Earl and I have talked about taking his and using it as a template to make a patteren. Him now living in S.C. has made that almost impossible.
  9. Earl Branham
    Lugoff, SC
    Frank, if you need the car, we can get it when I come to get the windshield tended to. Just need the measurements, right.
  10. 71gold
    we'll look into it then...
