Z-Bar frame mount
Discussion in 'Technical' started by jean282, Mar 19, 2007.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    hi i am looking for Z-Bar frame mount but i cant find one. I have 2 engine side mounts do you think i can use one to fabricate a frame mounts? if you have any idea just tell me thank you
  2. rayzorsharp
    Do you have the engine mounts for a v8 or 6 cyl? If you had the correct one for a v8, I might be able to come up with the frame side to trade you with.
  3. bmcdaniel
    bmcdaniel Senile Member
    You can buy them from any Mustang supply house. The plastic ball OD is different depending if you're running a 6-cylinder (small diameter, same as Mustang) or an 8 (large diameter, Maverick specific?)). I used all Mustang linkage on mine, including Z-bar. You could easily fabricate something with a piece of angle iron and your extra mount.
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    6 cylinder or a v-8 ??
  5. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    is for a v8
