1959 ford f100
Discussion in 'Other Automotive Tech & Talk' started by RUBEN, Jul 3, 2011.
  1. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    I just bought a ford f100, its has a 1979 302 and was wondering what headers would fit and clear everything. Thank you for reading
  2. Craig Selvey
    Might try asking that question on a F-100 Message Board.
  3. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    I made a username and everything on the ford truck forum and it just kept logging me out so I couldn't search or post anything. So that is why I asked here.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Try Speedway motors. They have a lot of swap stuff for older pickups.
  5. JHodges
    JHodges thumper
    Dora Alabama
    if it still has the straight axle it may be hard to find a set of headers that will clear the steering box. I'll post over on fte for you to see if they have any ideas
  6. JHodges
    JHodges thumper
    Dora Alabama
  7. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    doesnt have a straight axle in the front. thank you guys so much for all the help.
  8. JHodges
    JHodges thumper
    Dora Alabama
    what kind of suspension does it have
  9. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    I will check tomorrow.
  10. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    maybe it has a straight axle. it has a bar going from side to side.
  11. JHodges
    JHodges thumper
    Dora Alabama
    does it have an I beam style axle with a leaf spring on each side
  12. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    yes it does.
  13. JHodges
    JHodges thumper
    Dora Alabama
    then thats the factory frontend. The headers the guys on fte reccomended should work then. I have never tried to put headers on a 302 in one of those trucks though
  14. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    thank you for the help.
  15. JHodges
    JHodges thumper
    Dora Alabama
    no problem
