Hello, I am trying to remove the hingr form my quarter glass and cannot figure it out. Theres a nut that I loosened but the hinge is still attached. Looks like there might be a pin that has to be removed? To clarify I am referring about the hinge that mounts to the inside of the car. can someone please advise?
Yes the pin has to be removed, not an easy task while quarter window is still on the car. I would remove the window by undoing the 2 screws behind the piece of plastic that is mounted to the sail panel, it is covered by a plastic cover be careful not to destroy it. You will then be able to open window farther, then there three screws at the front of window that must be removed. After you remove them window will come all the way off. Why do you want you remove the hinge ?
