3.00 rear gear??
Discussion in 'Technical' started by 71gold, Nov 18, 2003.
  1. 71gold
    can someone tell me what if anything changes when you go from a 2.79 to a 3.00 rear gear. speedo and rpm. can speedo be brought back to stock reading if it is slow/fast? thanks...frank...:bananaman :bananaman L.T.N.G.
  2. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    To tell you the truth, I don't think you will notice much difference.
    Non-stock tire diameter is probably a bigger difference...
  3. Mavaholic
    Your speedometer will be slightly off. It will read faster than you are actually going. You can buy the correct speedometer gear from any Mustang supply house. They are a breeze to install.
