hey guys...ive come to ask for more info! ok...so will a 331 or 347 stroker engine fit in my 76 mav??i have the link for the specs http://www.fordcobraengines.com/331stkLB.htm ...i really really like this engine...do you think i can make it work?? on another note. do any of you know what someone might charge to put one in for me?? i dont know how do do it yet......thanx-james
The stroker is a 302 with a longer rod which gives it a longer stroke, hince the name stroker. So yupper, it will bolt right in providing you have the 302 frame mounts to begin with.
kewl so is that why they call it a 331? i though it would still be 331 cunbic inches...so wouldnt a 331 be 331 cubic inches as well? my car has a 200 in it right now..im not sure if it has the frame mounts for a 302...if i don hve them what options do i have?
Yes, it is 331 cubic inches. The longer stroke gives the bigger displacement because the piston moves further down in the block. Displacement is a product of bore and stroke, so if you change either, the displacement changes.
so..... so will it fit in there though?...i know it would be a tight fit if i could..but im thinking this is the engine i will go with if it fits :confused:
