428 Cid
Discussion in 'Other Automotive Tech & Talk' started by 1970mavinator, May 30, 2008.
  1. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    Are there any lower profile valve covers available for a 428 than the ones that came stock???
  2. Mavman72
    If it has the cobra style aluminum ones the stamped steel ones from any other fe should fit.
  3. 1970mavinator
    Ruskin, FL
    Its not a cobra jet, it is in a 66 t-bird i have. I was just wondering if there were any valve covers that are lower in profile than the factory ones, in order to give more room to work. There is not alot of room to change the plugs. I might not have the right tools but I couldn't get to them without taking the valve covers off. I got the passenger side off no problem but the driver side has the A/C compressor and the brake booster in the way and I cant even get the valve cover off without moving the A/C unit. I feel there is an easier way but I am just a rookie!!
  4. Mavman72
    I had a 64 T-bird with the 390 in it.I dont remember the plugs being that difficult even with A/C but it was 20 yrs ago.Sorry I cant help you more.Good luck.
  5. blugene
    Never been under one myself but sometimes it's easier from the bottom or the sides... i'm sure you thought of that.
    In my younger years, plugs were always done from the top, then I got a job where they had a lift. I began to see all types of different approaches, even if I had to use a long extension or remove a wheel...
  6. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Not sure on valve covers for you, but they aren't all that tall to start with stock.
    I have a 390 in a 66 F-100 with headers, power steering and power brakes, and its not all that hard to get to. (of course this isnt a car either) but I dont think shorter valve covers are gonna help much. (not sure on what you have either)
