5.0???????
Discussion in 'Technical' started by Mavericknutt, Jul 19, 2003.
  1. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    I am planning to do the 5.0 efI aod into my wifes 4 door and I found a 1987 mercury marquis. my question is...... will it be a roller motor or not??? I plan on picking the car up either way($150 and it runs) but the roller would be a bonus....Thanks:)
  2. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Im not sure about the marquis, but I thought that 1986 was when ford went to the roller motor.
    -Todd:)
  3. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    yes, its a roller
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I always thought only the H.O. was the roller?
    Dan
  5. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    yes its a roller, but the high output has a differnt cam and fireing order ( among a few other differnces ) but it certainly can be done.. keep us posted..
  6. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    thanks for the info guys:)
  7. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    hey one more???? I did'nt look to see......will it be speed density or mass air?? I assumed it was spped density but did'nt think of it while i was there.
  8. badmav70
    badmav70 Member
    pittsburgh, pa
    it should be speed dencity. my brother has an 89 that he just rebuilt it was speed dencity
  9. Will
    Will I
    Waco
    ditto on the speed density, I've got a 87 Merc Wagon thats speed density
  10. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    thanks for the info guys......her's will have to wait till I can get mine on the road but I have already been doing the resurch for hers........what can I say a big block in mine and a 4 door with the 5.0EFI FAOD lowerd just a little and set up like a touring car:) both will be quite the sleeper setup:D what can I say.........I am the nutt:D
  11. badmav70
    badmav70 Member
    pittsburgh, pa
    that sounds cool, i cant wait to see a nicely done 4 door..
  12. jeremy
    jeremy I build t5's
    Corona, Ca
    the 5.0 HO can be had for a dime a dozen now adays, and there is a good difference in power between the two, though I am not sure on the Numbers, just my opinion, but I would hold off on that engine, and look for a HO mass air donor.
  13. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    PS, speed density is fine if your not going to hot rod the engine to far.
  14. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    :D I knew you were out there some where Ken.......And thankyou thats kinda what I was thinking too. :)
  15. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Bob,...The only limitation on speed density is the cam timing can't get out of hand to far but there are some cams that will improve the setup. Cam lobe center has to stay at least 114* or higher.
    The Map sensor needs to tell the computer about the relative engine load via vacuum level. If a cam change for performance lowers the vacuum level to far the computer input become mismatched from the original engine model.
    I run a blower on my SD engine that has a blocking device to the Map sensor when in boost condition. This is a very succesfull setup and make about 300 hp. The setup smoothly makes improved power right off idle even before boost starts at 1800 rpm.
    Were into building a 540 hp 351 now for sprint car racing next season so I get to do another new project and have been offered the use of an engine dyno for the final test and tune.
    Best...
