5 lug rear and front end
Discussion in 'Technical' started by William, Apr 7, 2002.
  1. William
    William Member
    Heavener, Oklahoma
    1971 Ford Maverick
    what all is needed to do this swap??? right now I have a 71 Maverick with 4lug rearend and drum brakes??any help will be appreciated
  2. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    For the front end, I beleive you can swap to V8 drums (although they may be bigger). If not, you can swap spindles and go to front disc brakes as outlined in http://www.maverickgrabber.com/frontdisc.html
    For the rear, you need to change the entire rearend. It is a very simple procedure.
