70 Mav: pressure building up in gas tank
Discussion in 'Technical' started by tom mulloy, Mar 22, 2003.
  1. tom mulloy
    tom mulloy Senior Vice President
    Green Bay, WI
    1970 Grabber
    My 70 Mav (non-emissions) gas tank is not releasing pressure.
    Last weekend when it was nice outside I had the garage doors open so the sun was hitting the back of the car. I smelled gasolins fumes and noticed that gas was bubbling out of the rubber fuel line in the engime compartment (not hooked up to the fuel pump, open end plugged). I loosened the cap and a huge amount of built up pressure was released (gas gushed out as the pressure bled off). Figured I must have overfilled the tank, so I drained out about 10 gallons, but the next day it did the very same thing. This is not a CA car with the emissions stuff, so I know the gas cap is supposed to be vented. It doesn't seem to be allowing built up pressure to release into the atmosphere. If memory serves, vented caps have a hold in the middle and I believe there is some kind of spring loaded pop-off valve inside to release pressure. There is no such hole in this cap. I'm pretty sure it is the stock deluxe/LDO cap. Any ideas? Thanks.
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Tom, I have had this problem in the past too. My 76 Stallion has done this to me twice, and I had to repaint the tailight panel both times. I finally bought another gas cap, same as the one I always had and it hasnt done it since. But I never top the tank off anymore, so who knows if it is corrected anymore. Still remains one of life's great mysteries to me.
    Dan
  3. tom mulloy
    Green Bay, WI
    1970 Grabber
    Thanks for reply Dan. I'll look around for another cap.
