70 Maverick engine and auto transmissions
Discussion in 'Technical' started by Buzagi70, Apr 17, 2003.
  1. Buzagi70
    Buzagi70 New Member
    70 Maverick
    Hi,
    I'm helping a guy who bought a 70 Maverick two door. It has a straight six with blown head gasket and an automatic transmission with an electrical connector on the driver's side.
    How should I decode which engine and transmissions are in the car and where he should order parts for this car ?
    I need to ID the transmission in order to find the wiring diagram for the electrical connector and get a rebuild kit. I suspect that this is the original transmission that came with the car, do you know when they started to use lockup transmissions ?
    The carb also needs a rebuild.
  2. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    If this is a "lock-up" transmission, it's not original. Are you sure it's not just a connector for reverse lights?
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Though I don't think it was available until 71, if it's a floor shift the neutral safety switch mounts on the driver's side.
  4. Buzagi70
    Buzagi70 New Member
    70 Maverick
    This is a rectangular connector with two male and two female prongs. Any idea ?
    How I should ID the transmission ? We need to reubild it.
