72 Maverick IVR ??
Discussion in 'Technical' started by Chief1010, Apr 5, 2016.
  1. Chief1010
    Chief1010 Member
    Kentucky
    72 Maverick 306, 351W heads.. 75 Maverick ( parts car )... 71 Maverick ( in storage ).. 71 Torino 500 ,306, TCI Trans, Detroit Locker..
    Since my fuel gauge goes straight to full and never moves. I figured that the instrument voltage regulator could be bad.. I bought one, and I have crawled all over the dash to find it. No luck.. I guess the previous owner was kind enough to take it out.. Where is the IVR supposed to be mounted at?? Not having any luck on the Interweb??
  2. yellow75
    Tillamook Oregon
    It is on the speedo gauge cluster up high on left hand side. You will have to pull the cluster out to get to it. Not fun. If you unplug the fuel gauge wire at the tank what does it read, should be zero. If it stays at full you may have a short in wiring going to tank
  3. Chief1010
    Chief1010 Member
    Kentucky
    Got the IVR changed thanks yellow75.. Turned the key on and still goes straight to full ( actually past full ).. I've changed the sending unit along with the IVR, so I guess it almost has to be in the wiring from the dash to the tank.. It just keeps getting better and better..
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You have a short somewhere. I would bet if you did a continuity test between the wire and a ground you'd have your answer.
