74 mav uniframe
Discussion in 'Technical' started by maverickdad, Jul 25, 2003.
  1. maverickdad
    maverickdad Member
    Martinsville Indiana
    1974 maverick
    Part of my uniframe is a little bad. What about running a aluminum channel bar from the back frame to the front and bolting it on? Also for extra floor support. I figured aluminum because of weight.
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I think pics are needed for someone to give good advice on this one.
    Good luck with your project. Hope it all works out for ya.
  3. mavman
    mavman Member
    Arkansas
    There are subframe connectors out there made for reducing chassis flex. You can get them at Jeg's, Summit, etc usually for less than $100. The better ones require a slot to be cut in the floor for the tube to go through, but most others just either bolt or weld to the factory subframes. That being said, if your subframe is "bad" (depends on what's wrong with it) it might be better off replacing/repairing it. Good luck
  4. Mavaholic
    I would take it to a shop and have metal welded in there. Bolts will never be as strong as welding and aluminum has to be much thicker than steel to get the same strength.
  5. maverickdad
    maverickdad Member
    1974 maverick
    uniframe
    Thanks for the input guys. I`m taking it to a muffler shop at the end of september and I think they do that kind of work also.
    Steve
