'76 DISC SPINDLES ON '74?
Discussion in 'Technical' started by Powerband, Jun 22, 2016.
  1. Powerband
    Powerband Member
    NY's \H/
    I have a drum/drum 74 I want to put the Disc front spindles on from a '76.
    Parts applications are somewhat different from the 72-74's to 75-77 for front suspension and steering. What is the differences or what problems are their in swapping the spindles ?.
    Info or links to similar questions appreciated.
    thanks
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Should work no problem, I swapped a 75 to a 72 without issue.
  3. rthomas771
    Brake line fittings are different. I used an adapter between the brake line and caliper
  4. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    Don't hold me to it but outer tie rod ends might be different. Can't remember if it's the Granada spindles or later vs early maverick. Again been along time for me. Please someone correct me if I'm wrong.
  5. bmcdaniel
    bmcdaniel Senile Member
    Outer tie rod ends need changed and the brake hard line needs bent a little. I made my own brake line brackets out of some steel angle.
