This jeep has I6 258ci motor. however, the fuel line from pump to carb is not right. its working, i think. but i would like to make it right. my question is, can someone show me the proper fuel line route? be it picture or diagram. thanks for the help. Rick
http://www.jeepforum.com/forum/f8/fuel-line-pump-carb-258-a-328539/ No pictures and im not familiar with it but see if this link helps any.
Yeah that sounds like how mine was run on my 82 it was kind of a craptacular setup considering how often I had to pull off the plastic valve cover and reseat/replace gaskets because it would not stop leaking........ JMHO get an aluminum valve cover from clifford performance and get rid of the leaking plastic POS
ok- now im trying to put the steering column back together and every time i winch down on the lock plate to put in the snap ring, it bends. it has to be push down for the snap ring to go into the second grove. i cant figure this out.
