a little help needed
Discussion in 'Technical' started by Will, May 26, 2003.
  1. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    I'm not sure what I'm doing wrong, can I just loosen up one of the bolts on the tensioner so I can slip the alternator bolt the the bracket? check the pic
  2. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Wouldn't you want the belt off before you put the bolt in, and then put the belt on?
    Just a thought.
    Terry Gates
    AKA Bossmav
  3. gsjohnson
    gsjohnson Member
    Pasadena, California
    72 Maverick 5.0 EFI
    I agree with Terry, that's the easiest way to do it.
  4. jeremy
    jeremy I build t5's
    Corona, Ca
    I recognize that pic as being a late model 86-93 5.0 setup...is this correct??
    Put a socket on the tensioner, the round thing to the left of the upper radiator hose, you will want a socket and a breaker bar, and pull counterclockwise, this will relieve tension on the belt as the unit is spring loaded and will slide up. you then will be able to slip in the alternator belt.
    You may have figured this out already, but if you didn't, hope this helped
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    What Jeremy said.
  6. Will
    Will I
    Waco
    thanks guys
