When i install the lincoln rear end with the disk brakes do i use my mav porportioning valve or should i pull the one off the lincoln and use it ?
If you are going with 4-wheel disc brakes - you just need a distribution block - not a proportiong valve - p-valves are only for front disc - rear drum cars ..
