amperage question
Discussion in 'Audio' started by elchinelo72, Nov 10, 2008.
  1. elchinelo72
    elchinelo72 Member
    Los Angeles
    71and 72 ford maverick's
    ok,my head lights are h4 100/110 and as I was experimenting with 2 600W Amp's (4 12's) the ALT red light goes on and off @ times.
    if I turn ON the head lights with the fog lights (h3 120W EA) the red ALT light stays ON.
    what do you guys think is the problem:huh:
  2. mean_maverick
    lol, the biggest alternator to ever come factory in a maverick was a 65 amp job, so i dont think it can handle what you have. sounds like you need to kick it up a notch to a 100amp or 130 3G alternator
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Definitely need to upgrade the charging system.
  4. elchinelo72
    elchinelo72 Member
    Los Angeles
    cool. I forgot to mention I have a 100AMP alternetor so I should go 130?
    :thumbs2:
  5. maverick1970
    Missouri
    That is likely 100 amps max, you might be seeing 60 amps at idle. With the stereo cranked up and the headlights on, your probably drawing around 100 amps. An auto parts store that tests charging systems can probably check the load for an accurate reading.
    Check out the alternators from
    http://www.paperformance.com/Scripts/default.asp
  6. rthomas771
    Do you using a BIG ground cabe (4 gauge) on the amp's?
  7. elchinelo72
    elchinelo72 Member
    Los Angeles
    nope :hide: , I forgot.
    :biglaugh:
