i recently put in a 302 with 4 Barrel and a aod transmission. The transmission shop said that I need a tv cable for it to shift correctly??? if anyone has done this swap any help on what you did will be greatly appreciated thanks William
You need the hardware from a 84-84 Mustang that had the carb on it. Some larger cars around that time also have the hardware. Do not try to drive the car until you get the parts on and in reasonable adjustment or lose the trans.
