Bad motor mount?
Discussion in 'Technical' started by SweetHeart74, May 4, 2003.
  1. SweetHeart74
    SweetHeart74 Member
    Florida
    1974 2-door Ford Maverick, in-line 6 cylinder
    Hey all... '74 Maverick, 250 I6 here. Makes an awful shaking up to cruise speed (just started doing that yesterday) then smooths right out. How could I check for a bad motor mount on an I6?
    Also, I know the timing chain is shot.... gotta replace it this week. Could it be causing my troubles?
  2. SweetHeart74
    SweetHeart74 Member
    Florida
    Anyone know how to check the motormount?
  3. jeremy
    jeremy I build t5's
    Corona, Ca
    some signs: stepping on gas hard makes engine jump up.
    I had one go bad in my tbird, had initial vibration upon acceleration.
    Do a visual check, an old mount will look broken, cracked, split and all of the above. If your mount looks like anything other than a neat clean chunk of rubber, It wouldn't hurt to replace them.
    Depending on where the vibrationis coming from, you might want to check your driveshaft u joints as well.
  4. Mavaholic
    stick a floor jack under the oil pan and jack it up. Put a piece of plywood between the jack & pan so you dont dent it. If the motor mount is broken, it will separate from the frame.
  5. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    check the U-joints on the drive shaft
  6. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    What I always did in my old Chrysler was lift up the hood so I could see the engine from inside the car put it in Drive and hold the brake and hit the gas, and also the fan hitting the guard was a good indication :D
  7. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    you got it neal... that's how i showed my wife she busted an engine mount. i told her to not drop the car in gear on high idle...
  8. Doward
    Doward Member
    Yessir, it was the motor mount (I'm her b/f) and I'm gonna replace it in the morning - as well as the timing chain.
  9. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Hey! Drop that metal rod, it's lightning!!
    I would not recommend to someone to raise the hood, put the car in gear and rev it up while holding the brake down.
    That is a recipe for disaster in the right or wrong situation.
    Jack the motor up as Dennis described and look for separation
    at the mount.
    Seth
  10. scott
    scott Member
    new jersey
    uhhhh... i stood NEXT to the car
