Bad Vibes
Discussion in 'Technical' started by riporter, Nov 12, 2003.
  1. riporter
    riporter Member
    Charleston S.C.
    OK guys...she's on the road...kinda...been taken her out on test runs and doin some tweeking.
    My prob is when I shower down on it I get a vibration from the middle of the car. I checked the front u-joint and there is a very minimal amout of play in it...but there is some...it is an original joint...Im gonna change it tomorrow...the rear is new.
    Any other ideas on what it might be?
    Stuff like this just bugs the crap out me till its right..:(
    Thx Rick
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    the drive shaft could be out of balance or it could be a bad tranny mount or it could be...
  3. chandler
    chandler Member
    Warrenton Mo
    Maverick
    vibration
    Did you happen to take the trans. counter balance off, that will cause a shake on the tunnel.
  4. riporter
    riporter Member
    Charleston S.C.
    Im not sure what you mean by counter balancer...nothing came off the tranny that wasn't put back on.
    This is a problem that just presented itself today after the third test run and what was going to be the final tweeking of the engine.
    I think we have some more carb and timing adjustments to do.
    The vibration is in the tunnel though.
    One thing we did do...the car was scraping the tires with the wells...10" tires on the rear...we added an bottom leaf and fabricated a "wedge" for extra bracing for each side between the two bottom leafs...the car now sits about 2" higher than it did and bites really hard on takeoff .
    I dont see how this could have a vibrating effect...but i guess anything is possible
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I'm not sure what you mean by 'shower down on it'?
    Just kiddin'. I have never heard that one before.
    Are your motor mounts and tranny mounts secure?
    Is the harmonic balancer in good shape?
    As posted earlier, it could be in the driveshaft or
    the tranny.
    Good luck finding it.
    Seth
  6. Old Guy
    Old Guy Member
    Am inclined to think that your ride height mods have changed the pinion angle and trans ujoint angle. Even a minimal amount of wear in joints can cause some vibration. Under load the torque effect on these items is loading the drivetrain in one direction and then in deceleration, it is unloaded and symptoms like yours show up. Rear mount, angle and driveshaft balance is my guess along with that loose front joint.
  7. chandler
    chandler Member
    Warrenton Mo
    Maverick
    vibration
    Now that there is more info. on the post, I am more inclined to agree with Old Guy this same situation happened to my brother-in-law when he lowered his pickup, it all came down to the pinion angle. Strike another up for Old Guy.:bananaman
  8. riporter
    riporter Member
    Charleston S.C.
    Not too bad for an Old Guy...you were precisely on the money...after we added the front "Wedge" to the leafs and changed the U-Joint everything smoothed out. Im posting a pic of what we did to the suspension system to raise the rear...The ride is surpringly smooth and she bites really well. plz keep in mind these need to be ground...rust proofed and painted
  9. riporter
    riporter Member
    Charleston S.C.
    the rear height from a different angle
  10. Teammuir1
    Teammuir1 Member
    Louisville, Ky
    1971 Maverick Grabber
    Y did u weld that in there like that for
    HHHHMM that there makes me a little nervious...... DID u weld them in on the leafs??????
    if so... u know that the leafs are heated for the arch....and br welding them u might a caused some damage to them,,,,,,????
    After seeing what u did makes me wonder.....
    Y didnt just a small shim under the spring perch...????
    I HAVE NEVER SEEN THAT METHOD....
    Ron
  11. riporter
    riporter Member
    Charleston S.C.
    All the wedges did was fill the gap...they didnt make a gap so a shim was out of the question...the surrounding leafs at the welds were covered in heat paste and water cooled immediately after the welds were made... all the leafs appear to have maintained there integrity fine.
  12. Teammuir1
    Teammuir1 Member
    Louisville, Ky
    Pinion angle inclenation
    Normally,,,, people that change rear ends... trannies....
    get the pinion angle. wrong which in turns causes the
    problem you had described.....
    And the Proper fix...is a shim under the spring and the spring perch.... to pitch the axle thus getting the proper
    pinion angle inclenation......
    Like I said .... I have never seen that method done
    before... DIDNT SAY IT DIDNT WORK>>>> lol..
    but those shims I spoke of can be usually purchased at
    the local 4x4 shop... with diffrent thickness,, to acheive the proper angle that is desired......
    Ron
