best 250 upgrades?
Discussion in 'Technical' started by Rob C, Oct 24, 2003.
  1. Rob C
    Rob C Member
    nj
    74 Maverick 250 3spd auto 78trans am 400 "some" go fast goodies:)
    What are the best upgrades for the 250. i can think of a few but would like to hear everyones opinions.
    and no dropping in a 302 isnt an option!:rolleyes:
    although i do have a 302 that is in an 83ish (not positive) crown vic that is low milage. could it be a possible donor? if i were to swap motors out i would only take mainly the block and some other parts and build it up from there and make one sick street/strip mav. and yes with big bumpers :D
  2. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Rob,
    As far as the 250 goes, check out www.fordsix.com . . . these guys on this site love the Ford Inline Sixes. If that is what you are interested in, it should get going in the right direction.
    Good luck!
  3. RabidCustoms
    check with clifford performance, they can set you up with all the stuff you need for your 250.
    your going to want the port divider, I would shave the head .060 for a slight compression bump, some porting wont hurt,upgrade the cam, split header and for intake you either have to use a carb adapter for adding a 2 barrel or else mill the head to use a set of sidedrafts(2 or 3 your preferance) otherwise your stuck due to the intake being ntegral with the head. this set up is similar to one I built years and years ago.ran great with a really unique sound
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    rob WHEN ARE YOU GONNA JON THE CLUB?????? uhhhh not for nuthin, remember that mods can affect emissions and as you know, the great garden state will fail you at inspection time so be careful before you dump a lot of money into mods only to find out you can't pass emissions. go figure. california, maybe the most screwed up state in the world right now doesn't require smogging your car ( i think) but new freakin jersey does! how bad is that?
  5. Rob C
    Rob C Member
    nj
    in 48 days ill get my license and then after the holidays pass by and things calm down ill gladly join. and besides my car will look ALOT better after christmas. paint wheels and tires do wonders!! :clap: :bananaman
    and im sure if my trans am passed emissions i shouldnt have a problem with anything i do to the mav hehe :D
    would that 302 from the cown vic work?
  6. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
  7. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    Get a head from down under, Aussie heads have removable manifolds. Much more performance with their 2bbl head, and with some mods you can put on a crossflow head or just buy a complete crossflow engine.
  8. Rob C
    Rob C Member
    nj
    elliot did you get your cam from fordsix? did you like the quality and performance? was it a noticeable gain? and which cam did you pick?
  9. elliot
    elliot Member
    Boubon MO
    no I wish I did but they did`t have any yet when I got it and I haven`t even put it in yet because my engin needs a rebiuld and there is no sence in doing that part twice . What I`m gonna do is find a nice dusty shelf to put my cam on and get one from fordsixparts :D . Slow comet is right about the head you can get one from there too . when you get a header you will need to get a port divider too or you will blow out the exhaust gasket . there is other stuff you can do that isn`t made for the 250 , the conrod bolts and main bolts are the same size as the 289/302 so you can use the ARP stuff there . You can get a new webber 32-36 carb (330 CFM) from www.cliffordperformance.com or you can go to the junk yard and get the carb off a 80s ford astrostar van wich is a H/W 5200 (270 CFM) both of them should pas the smog test . The 250 has the SBF bellhousing so a T5 5 speed tranny will bolt up as long as you use a '0' balance flywheel you can get a stock replacement here www.partsamerica.com ,or get a billet steel or an aluminum one from ram cluches if you get one from ram cluches get one for a 1986 - 1995 mustang 5.0 157 tooth
  10. elliot
    elliot Member
    Boubon MO
    Rob C how much hp do you think you want to make ?
  11. Rob C
    Rob C Member
    nj
    enough that if im on the highway and need to pass someone i can without it taking me a mile to get by them. hehe :D
  12. elliot
    elliot Member
    Boubon MO
    well thats called second gear with you`r foot to the floor :D
  13. elliot
    elliot Member
    Boubon MO
    and like mav guy said you need to go to www.fordsix.com . How much money do / will you have to spend on it ?
  14. Rob C
    Rob C Member
    nj
    im used to the t/a throwin it down a gear and slammin that to the floor. but im not sure as to how much i got to spend im thinkg about dropping that 302 in it and making a sick street car.
  15. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Oh man, I sure wouldnt mind comin down to help if you ever wanted to swap in a 302. Did it in my car with a LITTLE help. Not hard at all.
    -Todd:)
