Biggest size for rears on a 9.5" wide with 3.5" bs
Discussion in 'Wheels and Tires' started by ESampson, Jan 17, 2011.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    I've searched and can't seem to find it, what would be the biggest tire size i can fit on my '74 Comet without any modifications it's a 15" Rim 9.5" wide and 3.5" backspacing thanks.
  2. mercgt73
    mercgt73 Member
  3. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Anyone else...? i really need to know so i can get this thing going
  4. injectedmav
    injectedmav Member
    Georgia
    I usually go to tirerack.com and find a tire brand that has sizes in that range (10"= 254mm width) and look at the specs for the tire in that specific size. they give you section width in inches, tread width, diameter, load range, tread wear, and the measured rim width. I've seen a 295/50R15 on one but I don't remember if he rolled the quarter panel lip.
  5. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    I think your backspacing is going to hurt you a little bit.....you will likely have your tire sticking out past the fender (ugly), then again it may not. My 10" rims have a 4.25" backspacing and I can fit a 28x10" MT slick w/ no problems.
  6. baddad457
    I have em on mine, but on 15x10 wheels with a 5" B/S and the lips are rolled and the springs stiffened. The only other choices are 265/50 (don't recall the brand, they're on my trailer in Kalifornia) and 275/50's. The 275/50's should fit on anything without mods
  7. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Alright so as it looks right now, ill be going with 275 50 15's, would it be possible to go to a 60 series though? if not ill just get the 50. thanks everyone
  8. baddad457
    275/60's are too tall. They're 28" in diameter. A full 1.25" taller than 275/50's
  9. Bryant
    im 90% sure that wheel will be under the outer fender lip. there is no way that you wont rub any tire on the fender with those wheels. sorry for the bad news but your back spacing is 1/2" too short and the wheel is just a little too wide. when running a 15 inch wheel your tires have alot of side wall buldge and that is what makes the wheel too wide to work with a maverck wheel well.
  10. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    alright then so whats the size im going to run guys? haha i gotta get this figured out...i don't mind if they stick out the side of the car as long as they wont rub.
  11. Bryant
    a 15x8 with a 4.25 off set seems to be the size that will work with a 275-60-15 tire. they may still rub. different tire manifactures will have different external dimentions. meaning some brands are bigger than others. you may still have to roll the fender lips to keep them from rubbing.
    if the tires stick out of the fenders they will rub on the fender over bumps.
  12. etgrabber302
    etgrabber302 Member
    townville sc.
    1971 maverick grabber with a 331 strocker c4 trans
    Rear Tire Size
    :thumbs2: my_new_motor_for_themaverickboss_302_011_original.jpg I have a set of jegs sport mags the_mav_with_new_wheels_005_original.jpg on my car 15/4's on front and 15/10's on rear with 4.5" bs. with 265-50-15 does NOT stick out past quarter panel part #555-69001 bs 1.75" front rear part#555-69031 bs. 4.5" the_mav_with_new_wheels_003_original.jpg
  13. injectedmav
    injectedmav Member
    Georgia
    THAT looks good!
  14. injectedmav
    injectedmav Member
    Georgia
    what brand tire are you guys using in a 15" that might be good for a street car? I do a little corner carving in the mountains, so drag stuff isn't really practical.
  15. etgrabber302
    etgrabber302 Member
    townville sc.
    tires
    :thumbs2: my_new_motor_for_themaverickboss_302_005_original.jpg my_new_wheels_007_original.jpg My rear tires are Cooper Cobra's my_new_wheels_003_original.jpg
