Black gasssy smoke..
Discussion in 'Technical' started by expjames91, Oct 19, 2002.
  1. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    well, my mav runs great now....some idiot disconnected the trottle selonoid....but now, my car smokes..black..not big clouds..but consistent..and it smells like gas....i adjusted the carb..it doesnt seem to be running rich...so, my question is,could this problem be caused by bad plugs/wires??they are ancient and carbon covered, because they guy before me had it runnin real rich...what about timing?? will that cause black gassy smoke??
  2. Craig Selvey
    There is no need to post a message in multiple forums on this message board....we just end up reading it twice.
  3. Stefan
    Montreal, QC
    I deleted the other one.
  4. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    sorry...ill remember that next time....
  5. Mav-Dude
    Mav-Dude Full Fledged Urban Redneck turned islander
    In the woods!
    69.5 Maverick/70 Mav Grabber
    No offense but two replys and all u guys did was bash him over the head and said nothing to help him on his problem:(
    Anyways, I had the same problem and I just adjusted the carb and that did it but if u already did that then it must be something else.
    hope your problem get resolved
  6. jeremy
    jeremy I build t5's
    Corona, Ca
    Understand that these guys donate their time to this board, and were not trying to bash him...They were just trying to get information across.
    If the spark plugs and wires are old, then replace them, however, they have carbon build up from a rich condition which is caused by too much fuel, not by the plugs being too old.
    Adjust your carburator properly. If it has been a while since it has been rebuilt, then you may be looking at a rebuild.
    Timing takes five minutes to correct. Would suggest the full tuneup, since you need one anyway. This will narrow down your problem significantly. Don't forget to do the points if it has them.
  7. K. Brock
    K. Brock Member
    San Antonio, TX
    1977 Mav, 2dr, p/s, p/b, 302 w/tremec 3550
    If your exhaust has black smoke and smells like raw gas, trust me, you're running rich. Keep adjusting, you'll get it right.
  8. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    It is possible and likely that the float is eather full of gas ( hole in it) or the float bowl valve or "thingy-ma-gigger" is not sealing properly.
    Black smoke and a fuel smell indicates a whole lotta un burned gas.
    Like they said, a carb rebuild or replacement could be the solution.
  9. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    yeah well, i fixed it...fixed all the problems...the choke was broked....
  10. david targhetta
    david targhetta member
    Albuquerque, NM
    1977 maverick w/ 302 V-8
    the factory setting for the two barrel carb used on the 302 is I think 3.5 turns out. Although unfortunately my memory is bad and its been like two months since i had tuned mine so it might be 2.5 turns.
