bought a welder (need help)
Discussion in 'Tool & Shop Talk' started by mavmike72, Aug 21, 2008.
  1. mavmike72
    mavmike72 Member
    louisville kentucky
    Bought a century duel mig 110 gas. It was set up for flux when i got it and it welded like $hit so i bit the bullit and got a tank with argon. What do i set the regulator on ? Right now it spits when you first start but then smooths out. So welding thin stuff is out of the question. Any advice ????
    :hmmm:
    thanks
  2. Mavman72
    what are you setting it at now??? 20 psi is normal for CO2/Argon/Stargon ETC...
  3. mavmike72
    mavmike72 Member
    louisville kentucky
    about 18. I have it set at 4 on heat and 2 on wire speed that seems to be the best so far. Maybe i just need some practice on the thin stuff...............
  4. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    mike
    Can you take a picture of the dials and post them
  5. Mavman72
    You may want to turn the heat down a bit for thin stuff.Make sure you are getting 18 psi when you pull the trigger(psi tends to drop off a bit when you pull the trigger).If not turn the regulator up so it pushes 18 psi when you pull the trigger.
  6. mavmike72
    mavmike72 Member
    louisville kentucky
    lol if i new how to post pic of my welder i would now how to put more pic of my car on..............................im computer stupid
  7. Mavman72
    With my Hobart on 4 I can weld quarter inch plate all day long.but I agree with lance put up a pic of the dials so we can see what your working with.
  8. mavmike72
    mavmike72 Member
    louisville kentucky
    havent checked regulator on the change when i pull the trigger but ive been lower on heat and it pops more but im no expert eather.........
  9. Mavman72
    Do you know what the current level is for each setting.Example... 1= 80 amps
    2= 110 amps and so on...
  10. Mavman72
    When you say it "pops" does it blow a hole in your work? or does the gun pop when you pull the trigger??
  11. mavmike72
    mavmike72 Member
    louisville kentucky
    pops when i pull trigger............trying to post pic give me a minute.....
  12. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    You need to reverse the polarity for gas welding. :naughty:
    Russ
  13. rthomas771
    To weld sheet metal with my Lincon I put the heat on 2 and wire feed about 2.75 and 20 psi gas. Be sure the metal is good and clean...no rust or paint.
  14. Mavman72
    :banghead:Doh!!!What Mr.Selkirk said.Im tired,im going to bed now.My eye hurts.
    nighty nite gang.Great catch Mr.selkirk(y)
  15. mavmike72
    mavmike72 Member
    louisville kentucky
    first it says invalid post specified when i try to post pic dont now what that means. How do i change polarity ?????????????
