Bought a welder
Discussion in 'Tool & Shop Talk' started by 1973Maverick357, Dec 23, 2009.
  1. 1973Maverick357
    Cookeville TN
    I bought a 135 Handler Hobalt FLux Core or Gas. It has the gas tank. Any tips? I paid $280 its in excellent shape. The guy had over $500 in it and hardly used it. Its 115 Volt i think not sure dont hold me to it lol.
  2. rthomas771
    Practice, practice, practice...and remember...just because it's not red doesn't mean that it's not hot. Ask me how I know
  3. 1973Maverick357
    Cookeville TN
    Well its not a 220 volt. Its a regular plug in.
  4. mavgrab302
    congrats, it's a really good light duty welder... great for floor pans and quarter panels
  5. 1973Maverick357
    Cookeville TN
    People have different opions on this, Use the flux core or the gas? Whats the advantages of gas?
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Flux core is like using and arc welder, you get the pleasure of cleaning up slag after you weld. Use the gas!!!!
  7. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    flux burns too hot for sheetmetal.
  8. Jamie Miles
    Gas all the way.
  9. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    You cant weld with gas outside!....:slap: Well you can but it can be a pain if there is a breeze blowing and you are welding in your driveway, and that is depending on the direction of the wind, so if you do that you might want to look into some flux core for that. Otherwise if it is in a controlled wind free area that will not blow all of your shielding gas away then yes definitely get gas.:hmmm:
    Oh and the Hobart is a good welder I have the big brother too it the handler 140 and I use the crap out of it.
    Make sure you go down to your autorized Miller dealer and check out what gun you have. If yours is two or three years old you might have the old hobart gun that is kind of a pain to get parts for, If you do you might want to look at one of the Twecko replacement guns with a 8' or 12' lead, they are a couple hundred buck but they are worth it. (PS Miller owns Hobart in case you didnt know)
  10. 1973Maverick357
    Cookeville TN
    The gun says miller on it.
  11. RMiller
    Kennewick, WA
    This is why they say commen sense isn't so common:hmmm:!!!! I open the garage door when I weld so it doesn't stink up the house. There's usually a nice breeze blowing that helps clear it out. Those are usually the times I have the most trouble with my work and not once did I consider the gas beeing useless in this situation.:huh: Oh well, I don't do too bad for an ametuer with a 110 Campbell Hausfeld.
  12. 1973Maverick357
    Cookeville TN
    Lol it took us 2 hours to get the wire through the feeder long story lol We used half the role too it just wants to hop off. Im gonna practice alot before i start on some floor pans or quarter panels.
  13. 1973Maverick357
    Cookeville TN
    I have a question. How come it will weld real good for like 2 seconds then it will like start sputtering. What is it that i can fix it. Maybe you can help me check off this problem.
    Here are the 3 things i was thinking.
    The ground isnt touching both peices of medal im welding.
    The wire feed is to fast or to slow.
    The medal im welding isnt clean.
  14. rthomas771
    The metal has to be clean or it will sputter
  15. 1973Maverick357
    Cookeville TN
    oh okay thanks thats what i thought. (y)
