Brake light switch
Discussion in 'General Maverick/Comet' started by fastfords, Oct 25, 2023.
  1. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    Does anyone know if there is a different b/l switch for power brake cars? I picked up a 74 Comet that was originally a drum brake cand the p/o swapped in power disc brakes (a good upgrade), the issue that I am having is the brake lights don't come on until the peddle is just about bottomed out.
    Thanks for your help,
    Chuck
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    IIRC the switches are the same for disc/drum, power/manual, but the brake pedals are different between power and manual. Someone will correct me if wrong.
  3. Krazy Comet
    The spring in manual brake switch is stiffer, used in power brake application can cause late/no activation. As far as aftermarket, I'm 99% one size fits all.
  4. fastfords
    fastfords Member
    East Tennessee
    Thanks for the replies. It does have the correct pedal, I guess I will have buy a new switch and try to mod it to work.
    Chuck
  5. jasonwthompson
    Carrollton TX
    You may also want to get the bushing kit for it as well if yours are missing. Mine did not act right without the bushings.
    mojo and Krazy Comet like this.
  6. fastfords
    fastfords Member
    East Tennessee
    Thanks, I already put in new bushings.
    Thanks, Chuck
  7. Krazy Comet
    Couple years ago brake switch on my Cobra quit. Rummaged through my misc electrical drawer & came up with five/six brake switches. All were used so I did try depressing them, some were fairly easy others so stiff, could barely move them with my fingers. With meter, test proved none of the power brake switches would activate. &^&^# Anyway I dug around on ebay & found new old replacement stock for P/B. Box was pristine with no bar code or WWW-stuff, figured it was probably 30+ years old, works perfect.
  8. fastfords
    fastfords Member
    East Tennessee
    Thanks, I might look into trying to find one that is nos for p/b.
    Chuck
  9. Craig Selvey
    As stated, the power disc brake switch is different that a manual brake car.
