Brake shoe opinions
Discussion in 'Technical' started by Crazy Larry, Dec 12, 2017.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I noticed that rivited brake shoes cost around 15 bucks more than bonded.
    Is riveted really any better than bonded?
  2. Acornridgeman
    Wisconsin
    The only advantage a riveted shoe gave back in the day, was that you could reline them when worn out. I actually had a shoe press and all the rivets at one time in the early 80's. Plus I had the shoe grinder which was like a drum sander for the asbestos shoes to even them out if they had a flat spot............... :sarcasticclap: :slap:............ Nobody does this kind of work anymore.
    I've never seen a quality pad bonding fail. Cheap ones yes, but never a good one.
  3. 71gold
    I pulled my Mother in laws rear brakes on her car and the factory pads had separated...(both on one side). the pads looked new, very little wear.
  4. rthomas771
    I seen the glue let go on cheap shoes causing the wheel to lock up. I wouldn't want to take the chance on saving a few dollars when it comes to brakes
  5. Mavman72
    Bonded for regular grocery getter duty...Rivits for heavy duty brake beating/heating kind of use...IE: Drag racing/road racing...You get the idea...:yup:
  6. 71gold
    that's what MNL was doing...
  7. 71gold
    Harold pulled this off a truck at his shop one day...:slap:
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Someone once told me the bonded shoes wear out sooner than the riveted ones...not sure if that is correct or not?
  9. rthomas771
    I read that semi-metallic shoes are for cars with power brakes and organic material shoes are for manual bakes. It takes less pressure to stop with the organic shoes.
