Broken wheel stud
Discussion in 'Technical' started by mrcomet, Feb 4, 2017.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Got a broken when stud on the rear drum brakes. Got the stud out and went to 5 different part stores and none had the size I need. Can anyone tell me the wheel stud part# for an 8 inch rear drum brakes and where to get it.
    Pictures of the original attached.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I got mine at the local parts store. It's a pretty common part and should be easy to find.
  3. Hotrock
    Munroe Falls, Ohio
    As Crazy Larry wrote, the stud should be easy to find.
    I used Auto Zone's website and found Dorman #610-109.1 was the correct stud for a `71 Mecury Comet rear drum brakes at $1.99 each. They were in stock at my local store.
  4. 71gold
    are you asking for a Maverick part or has it been measured for the size it is?
  5. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    I did get the Dorman stud Hotrock mentioned. But I can't get it to pull all the way in and seat. Does it need to be lubed to help it pull thru. Would this indicate I don't have 71 axles.
  6. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    For 71 Gold's reply. This is for my 71 Comet. There are a couple of studs in the Autokrafters catalog and one in the AMK catalog. Seems we are talking 1/1000 of inches to determine whether it will fit.
  7. Acornridgeman
    Wisconsin
    They get pressed in - I agree on the Dorman 610-109
    Don't try and pull them in using the threads and a lug nut. That can damage the threads and stretch / stress the stud making it prone to failure. Pressing in is the way to go.
  8. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Sorry for the novice question. Does the axle have to be pulled to have them pressed in. Or is there a tool that can do it while they are still on the car.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I used the Dorman stud from Autozone. I've always had good luck pulling them in with a nut on the threads. While using a press is the proper way, I've never had a problem the other way, and it beats having to pull an axle. The part is cheap enough that if you mess up the threads, you're not out much money. Try some motor oil on the splines.
    Ronald Hopkins and 71gold like this.
  10. 71gold
    I'm with Crazy, with the torque specs on a lug nut, there should be no ill effects on pulling it on with a nut...JMO
  11. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I can't remember how many wheel studs I've Replaced in my life time and I never pulled an axle. I have all always pulled them with the lug nuts.
    Crazy Larry likes this.
  12. Acornridgeman
    Wisconsin
    I've seen it done while in the car, using a stack of washers and an old lug nut to pull it through. There is no tool for an in car install that I know of.
    But I still prefer the way I was trained in mechanics school - and that was to use a press.
  13. yellow75
    Tillamook Oregon
    Might be able to throw the stud in the freezer and heat the axle lightly with a heat gun. I replaced all of them on my car with longer studs for racing purposes and never had a problem
  14. 71gold
    you were in training to get paid by the hour...:huh:
