budget 460's what did it run
Discussion in 'Other Automotive Tech & Talk' started by JHodges, Sep 18, 2010.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I was talking with another member who had a 460 mustang and it impressed me. At a later date I would like to build a 460 powered coupe. I would like to run high 6's na and maybe low 6's on nitrous. I was thinking a 460 with flattops and d0ve heads, not sure on the cam, should go high 6's in a gutted fox body pretty easy. I have read where several people have done this but then I read where a similar combo runs 7.90's so it throws me off. lol. I was talking to a guy at the track who had an 83 coupe with a late 70's 460 stock other than cam performer 460 intake and 850 holley. It even had stock manifolds on it. stock converter and 4.10 gears. He ran an 8.12 at 87 and it was missing a little. He said it ran a best of 7.80's. Anyway what it a good budget combo for high 6's na with a 460
  2. justin has a 74
    kentucky
    I have a book on 460s if you pay shipping there and back.
  3. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
  4. maverick75
    On that forum they have a nice budget build that makes about 500 ft lbs! They showed it in PHR a while back.
  5. JHodges
    JHodges thumper
    Dora Alabama
    cool I figure if it went 7.20's in a 3400lb car it should go high 6's in a gutted fox body. Have you ever sprayed the engine that went 7.20's
  6. YellowStangDuan
    Arlington, Texas
    71 Grabber
    Never sprayed the new motor, I put a glide in it at the same time and I'm afraid to hit it with the extra launch HP. The convertor is too loose, it goes to 4,800, and I shift at 5,500. I lose a lot of torque. I think it might go low 6.60's juiced. One thing to think about is you won't need above 4.11's, 3.89 would be good. Use the torque to go fast.
  7. JHodges
    JHodges thumper
    Dora Alabama
    can anyone give me a crash course on 429-460 heads, which ones make good power and which ones are smoggers
  8. tim keck
    sharps chapel,Tn
    you want C8VE, C9VE, or DOVE heads. I think the '71s are ok too. Stay away from the D2VEs, they are a one year only head and they suck. Really detonation prone. The D3VEs are low compression, but run ok with some work. Supposedly putting an early set of heads on a later block gets you about 10:1, about right for 93 gas. I'm not mentioning the old CJ heads 'cause I figure you're on a budget, a word usually not mentioned when referring the anything CJ.
  9. JHodges
    JHodges thumper
    Dora Alabama
    are c8 and c9 68 and 69 model heads.
  10. JHodges
    JHodges thumper
    Dora Alabama
    also what would the compression ratio be roughly with early heads and flat top pistons
  11. justin has a 74
    kentucky
    Your going to make me scan this book, arn't ya?
  12. YellowStangDuan
    Arlington, Texas
    71 Grabber
    D2's are junk as stated, don't count out the D3's, that's what my old 7.60 combo used. If you build a stroker, which is pretty cheap too, they help make compression manageable.
  13. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Budget 460 that runs 10's:
    .030 or .060 over with Keith Black hypereutectic flat tops
    stock rods with good bolts and bushings in the pin end
    stock crank
    Mellings standard oil pump with ARP pump driveshaft
    stock oil pan/pickup
    '68/'69 heads with bowl porting/2.25" intakes-1.75" exhaust valves/screw in studs & guideplates
    Comp Cams Extreme Energy Hydraulic Cam - 34-250-4 (XE284H); .584/.588; 240/246; 110 lca. Springs/retainers to match
    Hardened Pushrods
    Harland Sharp rockers
    Edelbrock RPM or Weiand Stealth (Offenhauser Port-O-Sonic if you can find it)
    Holley 850
    Good electronic distributor
    1 7/8" headers
    We had an engine similar to this one in Dad's '84 Thunderbird when he first bought it. With a C4 and a 4.11 geared 9" on 28x10 slicks it went 10.80's all day long.
  14. JHodges
    JHodges thumper
    Dora Alabama
    anybody else.
  15. Monsterpony557
    Monsterpony557 New Member
    the motor broke hole
    Wish I had a mavy
    Well I have a 460 which is a stock short block,C9 heads with 2.20/1.76 valves screw in studs comp roller tip rockers minor home porting ,a Lunati bracket master .545/.554 cam and stealth intake . It has MSD ignition and hooker super comps in a 1992 Mustang GT which weighs 3000 # a c4 3200 stall and 3.55 gears and runs 10.65 in the quater with no juice and 275/50/15 drag radials on pump gas .. . Id consider selling the complete drivetrain for the right money . Or just the motor , converter ,and JW Bellhousing .. The tranny is a nicely built C4 that I just freshened ..
