Cadillac 6.0
Discussion in 'Other Automotive Tech & Talk' started by blugene, Jul 30, 2010.
  1. blugene
    Anyone familure with this beast? 80 Eldorado FWD.. No start.
  2. Mavman72
    No crank or no run after crank???
    Do you have fuel/spark???
    Check fusible links at starter and check charge wire at altenator (the charge wire will kill the ignition sys if its not getting 12 volts at the alternator)
  3. blugene
    Cranks. It will run if I put a test light on the green connector by the dist. That's where I am with it so far.
  4. Mavman72
    This is an HEI Dist correct?
  5. blugene
    Looks like it.
  6. Mavman72
    Sounds like a bad wire connection between ignition sw and dist. Pull the plug and tighten up the spade in it so it makes solid contact with the pin in the dist. Its possible the wire is broken right where it exits the plug. Pretty sure thats the switch wire that you are jumping...
  7. blugene
    I am jumping the green plug wire that is just laying there. The underhood sticker says to jump it to check and set timing. Not at the shop to reread it..but that's what I read i'm pretty sure. Anyway, it's not connected to anything. The wire is brown in color. I am thinking it may be a ECM ground.. I can't find any info on the net.:(
  8. Mavman72
    Oh!!! Forgot about that wire!!! It locks out the computer timing advance IIRC...
    Its a ground...Sounds like you lost the ECM or have a broken/bad ground wire...
    There should be several ground junctions under the hood of that beast. Find em and check em/clean em
    Good luck Blu...
  9. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    What he said!!!!
  10. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    Did you get her running? L0VE THAT BEAST!
  11. blugene
    No. It's on the back burner for now.
  12. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    ECM problems are VERY common on 80's caddies. Of course the GM ignition switch doesn't help anything either.
